1968 Stick Shift Question
Believe its just glued on. Turn it upside down in a vice with a rag and spray a lil brake cleaner from the straw as close as you can to get in there to loosen the glue!thats how i replaced one with a chunk missin!
Hope it works for you.I tried that with no luck but mine wasn't missing a chunk. I called Pete from Hyper-Formance,he told me to wrap it with a rag, rest it on concrete or something hard and blast it with a hammer,worked like a charm lol. Good luck
Grind out a groove or piece of the plastic ball,it should come off easily. Why are you replacing it?
That's the problem I guess. I want to redo the silver "5" on the ball. I thought it would be easier to take it off. I don't want to ruin the ball.....
