Any Info Out There On This Fork?
Discussion in 'Vintage Mountain Bikes' started by 55ColumbiaBuilt, Aug 20, 2015.
  1. #1 Posted Aug 20, 2015
    Sep 1, 2010
    34
    1
    St. Mary's County Maryland
  2. #2 Posted Aug 20, 2015
    Jan 10, 2008
    1,708
    282
    So Cal
    You get what you pay for and this is cheap...probably ok for cruising mellow trails at slow, reasonable speeds but will fail under hard use...fork on my bike was over $500, no comparison.
  3. #3 Posted Aug 20, 2015
    May 24, 2010
    3,135
    616
    Indiana
    Are you riding offroad? If not, save your money.
    If so, ride it rigid or watch eBay for a 1" Marzocchi fork.
    I just bought a 1999 Gary Fisher Hoo Koo E Koo which is a nice triple butted steel frame and I'm putting a Kona Project 2 rigid steel fork on it.
    Suspension forks are just extra weight if they're not good quality.
    I do plan to ride offroad but I'm used to not having suspension.
    kwoodyh likes this.
  4. #4 Posted Aug 28, 2015
    Oct 22, 2014
    353
    407
    Chicagoland
    Save your money. That's a heavy piece of junk. Try putting bars on with more of a rise to put more weight on the seat and less weight on your hands.
    Another point worth noting is fork length. A suspension fork usually has a longer overall length. That could slow the handling a bit and make a bike feel a little clumsy. Sometimes that's good, sometimes that's bad with older MTB's.
  5. #5 Posted Jun 13, 2017
    Mar 17, 2016
    25
    24
    Washington, DC
    Facing a similar situation , I considered used forks as well as new
    Consider that the cost to adapt from theaded to threadless or vice versa is a low and widens your limited options when looking for 1" forks ,
    consider also the Shorter your steer tube requirement the more options you have .......
    in my case
    picked up a sweet 1993 cannondale MTB with broken fork , and spent 6 months looking for 1" cannondale fork
    ended up with a few used forks I didnt finally decided to install ....
    actually hunted for months on ebay for a 1 " .... tedious ! found a nice 1 " rigid and bot it only to find the seller mismeasured!
    Finally went with a new suspension fork with 1" steer tube for $60 bucks shipped it was a suntour 100mm travel , I think a better option than above .. not rated for serious downhill , but as good or better what your bike likely originally came with
    Kona has a nice rigid ( in limited / special runs ) by a top brand about $80 that is light and a great alternative. check bike wagon
    The my used fork search route can be a needle in a haystack , and or the used one u get may need service , hence I ended up with a reject pile .
    #5 Lamont, Jun 13, 2017
  6. #6 Posted Jun 13, 2017
    Mar 17, 2016
    25
    24
    Washington, DC
    The fork I bot for 60 was a suntour XCM , and there is some very helpful description on another forum ( mbtr ) where a suntour rep ( doug) describes specs and hierarchy of models
    If my steer tube was a hair shorter , i would have put the Easton above on for period correct and performance
    hope that helps
    dnc1 likes this.
Loading...
