Artweld
Found this frame with the rear wheel and tire, the frame is slightly different then other frames that I have such as 1/2" wider near the upper brake fender mounting area and has a plate instead of the round tubing, also looks almost identical to the the mid 60s to late 60s frame but has a slightly different angle when it's put up next to the others, has a 36 hole rb2 hub with the older drop center rim that has that line along the edge with an almost disappearing edge, front chain guard mount in the hole in the bottom bracket, any ideas on the make. My plan is build a penguin style bike would this make a good candidate frame, thanks
