Dave you are right about Oxalic Acid being harmful! Thank you for posting this. It is a weird chemical to use. I have looked up precautions on it. It says never to get it on your skin as it will be absorbed and can cause problems. [kinda vague on the problem part]
What I have noticed is that when I mix it up there it does give off very light fumes. I mix it in a 5 gallon bucket in side the house. I set the bucket in the laundry tub and fill with only hot water. I have used this stuff with cold water but the hotter the water the quicker and better results. While mixing it there is a slight odor and ever so light burning feeling in my eyes as I am in a confined space indoors. Then I carry it out side and dump into a pool to soak the stuff I wish to de-rust.
Every time I have used this stuff for the next 3 days after I have noticed I am a little short of breath.
It goes away but has happened and can not be a coincidence.This stuff is no where near acids like muriatic, acid magic or wire wheel cleaner but still is harmful and a mask should be used when mixing it and Never use indoors.
[had a leak..... gallons of O X on the basement floor]
Fellow Caber "Chitown" has used Lime Juice with great success.
I do want to add that I do have asthma and take an inhaler. I have never smoked but have been in the building trades my entire life and have had my fill of breathing dust and now am affected by breathing any of it immediately.
I can't remember the exact circumstance but he acquired a large amount of the stuff and tried it. It worked so well he now will only use the lime juice. I have seen the results for myself and think it is as good as and certainly safer then oxalic acid.
This oxalic acid appears harmless but it is corrosive stuff and care should be used when handling and using it.
