I'm hoping you guys might be able to help me ID the frame, or what's left of the old courting tandem that it's built out of. I know it's a slim chance, but I figure it's worth a shot. It uses a fauber hangar and sprocket, and I believe there is the number 654 stamped on the bottom of the hangar. There may be more, but it's obstructed by an extra support for the engine
I believe it to have been built in the St Louis area, possibly Alton Illinois if that helps in any way?
I believe they used the front habger and frame section from the girls portion of the frame, and then used the original front bicycle fork to make the upper section of the rear frame. The rest appears to be home made... and quite beautifully I might add.
Thanks in advance!
Johnny
