Info On Rebuilding Morrow Hub
Discussion in 'Classic Balloon Tire Bicycles 1933-1965' started by Eddieman, Nov 22, 2009.
  1. #1 Posted Nov 22, 2009
    Eddieman
    Eddieman Look Ma, No Hands!
    Oct 25, 2009
    38
    4
    Garden State
    Hi - Any one have a instructions for rebuilding a Morrow? I took the hub apart and can't get the reasembled correctly. I have seen the exploded view that shows the parts but need some instructions.
    Thanks, Ed
    Tags:
  2. #2 Posted Nov 27, 2009
    MaxGlide
    MaxGlide Wore out three sets of tires already!
    Aug 7, 2009
    776
    12
    Vancouver
    Hub rebuild
    Well I have also rebuilt a Morrow hub and there is no written info on how to put it back together that I could find.
    What I did was simply line up the parts on a table as they were shown in the one diagram I found and pieced it together. It wasn't that hard and the brake seems to work ok (except I have to replace the sleeve as it has worn)
    Like I said, print a blow up of the diagram and go by that.
    Good luck..... Wayne
  3. #3 Posted Nov 28, 2009
    AntonyR
    AntonyR Wore out three sets of tires already!
    Jan 11, 2007
    615
    I have the Morrow service manual. Anyone who needs a copy(pdf), PM me your email addy.
  4. #4 Posted Nov 29, 2009
    AntonyR
    Jan 11, 2007
    615
    Don't forget to include an e-mail address in the P.M...
  5. #5 Posted Jul 2, 2010
    wheelie
    wheelie Guest
    need morrow service manual
    hi i am a new guy here and its great to find answers to problems that no one knows about. but iam in need of the morrow service manual ,with the bike upside down the wheel binds up when coasting ,the cones are set right.after the brake is applied it binds and then when you pedal again there is a chatter or slight grinding noise . plus if you walk the bike the pedals keep rotating.
  6. #6 Posted Jul 2, 2010
    wheelie
    wheelie Guest
    hi i am a new guy here and its great to find answers to problems that no one knows about. but iam in need of the morrow service manual ,with the bike upside down the wheel binds up when coasting ,the cones are set right.after the brake is applied it binds and then when you pedal again there is a chatter or slight grinding noise . plus if you walk the bike the pedals keep rotating. igotabike2@yahoo.com
  7. #7 Posted Sep 21, 2012
    pelletman
    pelletman Wore out three sets of tires already!
    Mar 15, 2008
    937
    12
    New England
    Did you get that hub fixed?
  8. #8 Posted Sep 22, 2012
    AntonyR
    Jan 11, 2007
    615
    He had two years, so I'd hope he'd fixed it by now...
  9. #9 Posted Jan 16, 2013
    AntonyR
    Jan 11, 2007
    615
    For reasons unknown, I can't find my pdfs on my computer, so I can't send anyone these until further notice...
  10. #10 Posted Jan 16, 2013
    abe lugo
    abe lugo I live for the CABE
    Sep 6, 2010
    1,157
    27
    Los Angeles,CA
    Thanks for bring it up
    I found an exploded view I can use for reference, if anyone else might have that PDF please pass it on.
    Abe
  11. #11 Posted Jan 16, 2013
    Dave Marko
    Dave Marko Riding a '38 Autocycle Deluxe
    Feb 16, 2008
    7,718
    257
    Portland, OR 97206
    This is what I have on the subject, although I don't remember which CABE member to credit for initially posting it. I'm trying to upload additional PDF Instructional pages with some difficulty. I'll keep trying.
    #11 Dave Marko, Jan 16, 2013
  12. #12 Posted Jan 16, 2013
    Dave Marko
    Feb 16, 2008
    7,718
    257
    Portland, OR 97206
    I couldn't upload the singe PDF that I had, So I had to turn it into 6 single jpeg's
  13. #13 Posted Jun 3, 2013
    Krautwaggen
    Krautwaggen Cruisin' on my Bluebird
    May 24, 2010
    2,867
    133
    Indiana
    Thanks for posting this Dave!! I rebuilt my first morrow hub this evening and it would have been a little confusing without the manual.
  14. #14 Posted Jan 17, 2014
    bbrown1030
    bbrown1030 On Training Wheels
    Apr 28, 2013
    3
    Anchorage. Alaska
    Thanks Dave
    Thanks Dave for the great info. I was already planing to take mine apart to check the condition before I spend a lot of time cleaning a bad hub.
  15. #15 Posted Nov 11, 2014
    Wheeled Relics
    Wheeled Relics Cruisin' on my Bluebird
    Apr 16, 2013
    2,514
    89
    Portland, OR 97214
    Morrow hub manual
    Found this morrow hub manual while searching for causes of a morrow hub forward slip or slipping after reaching the top of a hill, the drive feels fully engaged, as the torque relaxes as the top of the hill, it slips and feels a little like floating. The coaster re-engages and slips a couple times before fully engaging steady again. It seems to happen at the top of every hill or on long straightaways with steady pedaling. Pg. 81 & 82 address possible causes of slipping.
    Thanks for posting the Morrow manual Dave.
    #15 Wheeled Relics, Nov 11, 2014
  16. #16 Posted Nov 12, 2014
    Wheeled Relics
    Apr 16, 2013
    2,514
    89
    Portland, OR 97214
    D. none of the above
    In the Morrow Manual on page 81:
    "Driving Troubles"
    1. Slipping
    d. cone and axle assembly may not be put together properly
    (Pg85-87 Cone & Axle Assembly)
    In the following thread :
    http://thecabe.com/vbulletin/showth...ems-need-help/page2&highlight=Morrow+engaging
    post #11 suggests axle can be tricky:
    "Morrow hub can be a trick to reassemble. The two parts that go on the axel, with the spring between them,(clutch?)must have proper clearance for thing to work right. I think the clearance is 1/32 to 1/16th of an inch. What I have done in the past, if thing don't work right, is take only the outer piece of the clutch off and try to thread it back on the axel with the clearance as close as possible. It seems that too much clearance and either the braking issue or the same type of problem when pedaling forward."
    I don't see any information in the manual touching on slipping / axle assembly tolerances other than a reference to (d. Cone and axle assembly may not be put together properly)
  17. #17 Posted Nov 13, 2014
    Wheeled Relics
    Apr 16, 2013
    2,514
    89
    Portland, OR 97214
    Morrow hub slipping forward and axle assembly
    After a head scratch about why this morrow hub is slipping forward, I may have found the culprit. When assembling the axle, the two keyed pieces on the brake arm side w the spring between them need to be threaded on together. I took apart the hub in question and examined it carefully, noticing the keyed slots having a space on the hub slipping, I compared to the keys/slots being fit together on a working hub. In the manual in the axle assembly section it says these "extensions 'must' fit into the slots. This is important." ...
    #17 Wheeled Relics, Nov 13, 2014
Loading...
