Instructions on How to rebuild New Departure Hubs
Discussion in 'Bicycle Restoration Tips' started by MOTOmike, Aug 5, 2012.
  1. #1 Posted Aug 5, 2012
    May 9, 2012
    373
    39
    MD / Washington, D.C.
    Does anyone know of a good book or something online that explains step by step instructions on how to rebuild New Departure hubs? I have a Model A rear hub that I want to rebuild before I lace it into a new rim and I don't want to screw anything up.
    Any suggestions out there on where to find step-by-step instructions?
    Thanks,
    Mike
  2. #2 Posted Aug 5, 2012
    Sep 6, 2010
    1,306
    221
    Los Angeles,CA
    there a good thread on ratrodbiked
    Basically,
    Carefully take apart, drop parts in solvent.
    You probably want to make sure your disc stack is very close to .75", then lightly clean them if they are glazed, with some steel wool.
    make sure to also clean the outer bearing (cog side), that one is a reverse thread on the cap.
    In the center want to make sure the little spring that goes into the clutch is not broken.
    clean the inside of the hub.
    grease bearings, oil the discs.
    Make sure the cones are tight them backed off alittle bit.
    sometimes you may have to hold the cone with a cone wrench as you tighten the wheel in.
    here is the link
    http://www.ratrodbikes.com/forum/vi...=0&st=0&sk=t&sd=a&hilit=new+departure+rebuild
    hope this helps.
    if you have no brakes it's either the spring clip broke or too loose on the cone.
  3. #3 Posted Aug 5, 2012
    Jul 5, 2011
    2,297
    78
    Buford GA
  4. #4 Posted Aug 5, 2012
    May 9, 2012
    373
    39
    Rebuilding New Departure Hubs
    Thanks,
    When I take the hub apart, is anything spring-loaded that may "pop out"?
    I have read somewhere that white lithium grease is recommended over bearing grease?? Any opinions on which grease to use?
    For oiling the discs, I have read where someone suggested 30 wt. motor oil. Is this generally what is used?
    Thanks for the reply.
    Mike
Loading...
