bairdco
Got a bunch of old hubs to rebuild, so I figured I'd do some step by step tutorials.
First up is the JC Higgins coaster, which is pretty much identical to the Musselman hub.
Here's the exploded view of all the parts in order:
Leave the spring steel collar on when cleaning, and assemble the driver parts so the serrated gears are together.
The spring steel collar is about the only part in these hubs that can fail, and if you put the smaller driver on backwards, your hub won't work.
The threads on the axle are longer on the sprocket side:
Here's the guts cleaned and assembled:
