Love my Lenton....but
Discussion in 'Vintage Lightweight Bicycles' started by LouB, Jun 12, 2017.
  1. #1 Posted Jun 12, 2017
    May 5, 2017
    18
    18
    San Antonio
    as the title says...but that 49/46 Williams half-step chain ring and the Cyclo 5 speed (big ring is 22T) is just too tough for me to enjoy riding. First off--what were they thinking? be ok for Kansas or Miami, but cant imagine anywhere else that would have worked. So, if I'm going to keep and enjoy the bike, I need to change the drive train. I want to keep it old school. I have a 52/36 cottered crank that would slip right on. So...what to match up to it. What FD/RD and what free wheel whould work (upper 20's to low 30T's.) Not sure if there is anything British that would work, but that not critical...just want to enjoy this oh so British bike, retain its character as much as possible and not die on the hills around here. RLGP 03.jpg RLGP free wheel.jpg
    dnc1 and bulldog1935 like this.
  2. #2 Posted Jun 12, 2017
    Jan 21, 2013
    2,555
    2,595
    downtown Bulverde, Texas
    Lou, your front derailleur should work fine with your new crank/chainrings.
    Next trick is find a freewheel.
    You're going to have to remove the old one and measure the overall thickness (width), and match that with a new (old stock) freewheel.
    [​IMG]
    Good news is the threads should be easy to match.
    A call to Yellow Jersey would be smart - he can probably fix you right up, or make a great recommendation - he's also the first choice for rebuilding old freewheels.
    Any short-cage rear derailleur from the mid-60s through 70s should work fine with a 28t max rear cog. Chain wrap shouldn't be an issue.
    The 36T/28t combination would give you a 35" low gear, which should get you out of the Olmos Basin in any direction, just fine.
    Right now, your low gear is 57", and I can't blame you for squirming with that.
    (yesterday on the final climb, when I pulled away from you on my Moser, I was in a 66" gear, and made most of that climb in a 73" gear - just checked my gear chart).
    Any RD older than '86 should work fine with the cable pull of your stock shifters.
    I have a nice Shimano 600 EX RD you can check out - very high mileage, bought new in '78.
    [​IMG]
    Ran since '78 to about 6 years ago on my Grand Prix, and started off my Moser before I made the Chorus upgrade - it has the red jockey wheels below.
    [​IMG]
    I have that French stem set aside to bring next week, I'll add the RD to the cigar box
    If you want to keep your RD in the family, look for a Cyclo Super 60 RD
    [​IMG]
    But the Shimano 600 EX is probably a better RD, and came new on many race bikes into the late 80s
    And IMO, there is no better FD than Shimano 600 EX - still running on my International.
    [​IMG]
    #2 bulldog1935, Jun 12, 2017
    dnc1 likes this.
  3. #3 Posted Jun 12, 2017
    May 5, 2017
    18
    18
    San Antonio
    That just makes perfect sense. I'll get cracking on this. Its too sweet a ride to part with! Thanks Ron.
  4. #4 Posted Jun 12, 2017
    May 5, 2017
    18
    18
    San Antonio
    Just realized I have a Suntour GVT, long cage. That would work also--correct? with the correct width free wheel.
  5. #5 Posted Jun 12, 2017
    Aug 15, 2012
    907
    490
    Washington, IL
    Ron, I have a Shimano 600 group of that same vintage minus that RD; if it is a spare I would be interested
    Krautwaggen likes this.
  6. #6 Posted Jun 12, 2017
    Jan 21, 2013
    2,555
    2,595
    Yes, it would work, but you don't need the long cage and big chain wrap. That kind of chain wrap is what you need with a triple, or if you go to even larger rear cogs (32t)
    [​IMG]
    If you start going too wide with 5 rear cogs, (wider than 14-28t) with the 52/36T crank, you're going to have such cliffs in your gears (giant steps between gears) that you won't be able to ride with a group.
    here's basically the gear chart we were discussing above - look at the semi-log graph and remember most of our riding is 65" to 85" - this the range narrow steps are a benefit, especially trying to keep up with friends on newer bikes.
    It would be better if you could make that 52T ring smaller (48 or 49T on the big ring would be perfect)
    What you don't want are gear steps larger than 10 inches from about 50" to 85+/-"
    You wouldn't want wider rear cogs without going back to half-steps on the rings
    However, look at this option using even wider rear cogs with the VGT, your original 49/46T half-step crank, and a 14-32t 5-sp freewheel (or even 14-34t)
    This is a really good half-step gearset.
    The low is equivalent to the lowest gear on my Moser (39"), and the steps are really nice for chasing in a group ride.
    You would find yourself using every gear with nothing duplicated.
    #6 bulldog1935, Jun 12, 2017
    dnc1 likes this.
  7. #7 Posted Jun 12, 2017
    May 5, 2017
    18
    18
    San Antonio
    That's brilliant. Sounds like an excellent solution.-- and I've got some of the parts. I'll pull the parts tomorrow, measure the free wheel and go from there. Thanks Ron.
  8. #8 Posted Jun 12, 2017
    Jun 27, 2008
    2,521
    1,166
    The British always seemed glued to high gearing. The stock gearing on a 3-speed or 5-speed internal gear hub bike was 48-18, even on the 28 inch wheel DL-1. The club bikes had nice, medium-ratio hubs, but then the medium ratio was applied to 48-18 usually, still pretty high if you have hills to climb. I haven't even bothered with an 18 tooth cog in years. I really like 46-22 on a 3-speed, but high gearing seems to have been universal for Raleigh.
    My 10-speed Grand Prix has 52 and 40 tooth front chainrings, which offers a pretty good range. In a perfect world, I think I'd rather do 48-40 or 48-38.
  9. #9 Posted Jun 15, 2017
    Oct 29, 2010
    1,932
    220
    San Quentin, California
    Measure the width of the freewheel???
    Most any 5 speed freewheel with normal threads will work..
  10. #10 Posted Jun 15, 2017
    Jan 21, 2013
    2,555
    2,595
    ??? o_O
    Not a 1960 Raleigh hub and axle with 114mm rear dropout spacing and 8mm axle.
    I know, I just designed and had a custom hubset built by Phil Wood.
    #10 bulldog1935, Jun 15, 2017
  11. #11 Posted Jun 15, 2017
    Apr 1, 2016
    582
    1,165
    Wallingford, Oxfordshire, UK
    This is why every british working man back in the '50's had legs like Sir Chris Hoy! Lol!
    SirMike1983 and bulldog1935 like this.
  12. #12 Posted Jun 19, 2017
    May 5, 2017
    18
    18
    San Antonio
    Got my Raleigh branded Suntour GVT derailleur and freewheel (14-32) today. Lovingly stripped the Benelux RD off and packed it up along with the Raleigh freewheel for future use. Now to install the new goodies, dial them in and get to riding these hills. I'll post pics when complete.
  13. #13 Posted Jun 19, 2017
    Jan 21, 2013
    2,555
    2,595
    I got more spanish cedar cigar boxes if you need them - great for stashing bike parts and fishing reels
    [​IMG]
    dnc1 and LouB like this.
  14. #14 Posted Jun 21, 2017 at 9:10 AM
    Apr 24, 2012
    764
    69
    Pella, IA
    Do you find that the 46-22 gearing makes the bike....sluggish or does it provide better hill climbing while being fairly speedy?
  15. #15 Posted Jun 21, 2017 at 1:26 PM
    Jun 27, 2008
    2,521
    1,166
    It makes high gear your cruising gear. Low and normal work as climbers or headwind gears.
    I would go 46 - 20 if you are not worried much about hills where you live.
    #15 SirMike1983, Jun 21, 2017 at 1:26 PM
    bulldog1935 and dnc1 like this.
  16. #16 Posted Jun 26, 2017 at 8:26 AM
    Jan 21, 2013
    2,555
    2,595
    not to derail Lou's thread, but on my daughter's Nexus 8, I turned city gears into touring gears by adding 2 teeth to her drive cog and taking 2 teeth from her chainring - gave her 4 cruising gears to 85", and 4 climbing gears down to 25"
    [​IMG]
  17. #17 Posted Jun 26, 2017 at 7:31 PM
    Jun 27, 2008
    2,521
    1,166
    I like having 2 different climbers for every cruising or downhill gear. I'm not sure there's a hard rule about it, but I follow that as a rule of thumb. I don't mind losing a little top end because I'm running original brake calipers on steel rims, which means it's really easy to out-ride your max braking power. If I broke 20 mph, I'd consider that pushing it on original brakes. But if you have the braking power to safely stop from a higher speed, then higher gear would work well.
    My theory behind high gearing of stock bikes is that the shops would get a large number of returns if people "spun out" too easily. If someone buys a bike and it's hard to pedal, they probably just say "I need to get better at this". If someone buys a bike, spins hard and gets passed by everyone, they'll complain. At least that's part of my theory.
    The worst offenders were the American-made balloon tire bikes. Many came stock in the 1930s with 52-18 equivalent gearing (skip tooth maybe, but same ratio). On a bike that already weighs 40+ pounds, that's nuts. They're fun to look at, but disasters from a gear/drive train perspective when you need to go uphill. I remember climbing some rather steep incline bridges over the local water treatment plant on one. It was brutal trying to power up those. Some of the coaster hubs are very well-manufactured though.
    The English 3-speeds were next worst because they just said "48-18" and that was the ratio for many years. They later went to 46-18, which is marginally better.
    Some of the early derailleur bikes from England also had some very high ratios, probably because they had club and competitive riders in their 20s-40s in mind.
    There's no shame in dropping the gear ratio to something more manageable. As I said, I haven't run an 18-tooth rear in years. I have a couple 20s, a few 22s and even a 24 (Raleigh Sprite 5-speed).
    Eric Amlie likes this.
  18. #18 Posted Jun 26, 2017 at 7:43 PM
    Jan 21, 2013
    2,555
    2,595
    Here's her Nexus 8 drivetrain with 22t drive cog and 42T chainring
    gear no. gain ratios/ gear inches
    1. 0.53 / 27.5
    2. 0.64 / 33.6
    3. 0.75 / 39.0
    4. 0.85/ 44.4
    5. 1.0 / 52.2
    6. 1.22 / 63.8
    7. 1.42 / 74.0
    8. 1.62 / 84.2
    anyone should be able to sustain a 15% grade on that low, which happens to be what is necessary to get home
    I set her up with this when she was 11-y-o - it was her first full-size bike.
    #18 bulldog1935, Jun 26, 2017 at 7:43 PM
    SirMike1983 likes this.
Loading...
