rollfaster
Working on a mussleman Higgins hub for a friend. He is restoring the bike and he gave me the rear hub to rebuild. It is a later 1/2" drive version. Have done several of these hubs(easy) but he wants to have the brake arm, hub shell and sprocket replated. The problem I'm having is trying to remove the sprocket from the driver. I've never had to do this before, usually just leave them attached. He has disassembled most of the hub and had taken the lock ring off already. Now I can't get the cog to unscrew from the driver. I'm guessing the threads are RH. Do I use heat, already soaking. Any help with this would be great. Thanks a bunch.
