I don't measure ND braking disc sets solely by disc count. They actually made several widths of discs over the years. What you're looking for is the overall dimension of the entire stack of discs. The count matters in that it should be close to 50/50 proportion. For example, if you have a set of the "heavy duty" type discs and clutches, you'll have fewer discs but the same overall dimension for the stack.
I checked a set of unused heavy duty discs/clutches. There were 17 total pieces in the braking surface set, counting both types of brake washer. The caliper settled at very close to 3/4 inch for them. They were heavier duty than the ones I took out of the hub I was rebuilding, and there were fewer of them. Some hubs it seems they used all steel, wafer thin pieces in greater quantity, and other hubs have thicker ones with bronze spinning washers. Regardless, the goal is right near that 3/4 inch mark.
The thicker discs have the disadvantage of lowering the overall surface area friction within the stack because you have fewer pieces. Their advantage is less propensity to crack or snap under load. You can crank down on those thick ones a little more, in my experience.
