Prewar Shelby Seat Cinch Bolt
Discussion in 'Wanted' started by saladshooter, Jun 19, 2017.
  1. #1 Posted Jun 19, 2017
    Nov 30, 2014
    443
    977
    Littleton, CO
    Howdy,
    I'm in the market for a seat post cinch bolt for a prewar Shelby. Let me know if you have a spare.
    Thanks
    Chad
  2. #2 Posted Jun 19, 2017
    Jan 15, 2010
    843
    136
    Westlake Ohio
    I believe that I might have one. Let me look and get back to you.
    saladshooter likes this.
  3. #3 Posted Jun 19, 2017
    Jan 15, 2010
    843
    136
    Westlake Ohio
    This is what I have available. The far left is a colson I believe and it is 1 3/8" long fine thread and it locks down the seat post and was for a bike without a carrier. If this one won't do I have 2 others available as well in the photo.
  4. #4 Posted Jun 19, 2017
    Nov 30, 2014
    443
    977
    Littleton, CO
    Howdy Ed
    I think the center one is what I'm looking for. But the picture is a little blurry. Does it have a "pin" on the top end on the shaft that fits in a notch on the seat post clamp to keep from spinning when tightened?
    How much you after?
    Thanks
    Chad
  5. #5 Posted Jun 19, 2017
    Jan 15, 2010
    843
    136
    Westlake Ohio
    Hi Chad, it is not a pin but a square. I can look to see if I have one with a strait line if that is what you mean instead of a square to keep it from spinning. Let me know.
  6. #6 Posted Jun 19, 2017
    Nov 30, 2014
    443
    977
    Littleton, CO
    I'm looking for a bolt with the middle head above and a key on the bolt shaft to align with the notch in the photo to stop the bolt from spinning when tightened.
    Thanks
    Chad
  7. #7 Posted Jun 19, 2017
    Jan 15, 2010
    843
    136
    Westlake Ohio
    I have one like that that has been replated on the far left and looks like someone added an S to it to make it a schwinn. It is for a carrier and is 1 3/4" in length minus the end.The one on the far right is AS and has 2 pins not one and is shorter and not for a carrier I don't think. The replated one is a quarter inch in diamiter or a little bit more.
  8. #8 Posted Jun 19, 2017
    Nov 30, 2014
    443
    977
    Littleton, CO
    Thanks Ed, but the only one that would work it seems is way too shiny for my application.
    Chad
  9. #9 Posted Jun 19, 2017
    Jan 15, 2010
    843
    136
    Westlake Ohio
    You could always remove the plating grind off the S and let it rust a little bit. I have access to a liquid that would help the metal get a slight rusty patina.
Loading...
