cool ... once they bond see if you can tear them apart
While waiting I stuck a loose connection on the top so I could monitor the hardness of the glue as it sets. I connected the other by using a small C clamp that was only tight enough for the two pieces of rubber to touch for a few hours, until the glue could hold it on its own. Then I'd know if it, while the glue was setting, had enough strength to continue holding with the force of the rubber wanting to pull them apart.
I only applied I gob of glue to 1 side of the top and bottom sections, without having cleaned or prepared any of the rubber:
On the Top piece; The main gob of glue has grabbed well but with little effort failed on opposite, unglued side :
The part in vise; A good pressing of the two sides, feels well joined as I prepare to pull.
Easily separated, and in contrast to the top connection, the glued side just cleaned the surface off of the tire while the bare side grabbed.. Go figure?
The section in the vise, the glue is saturated into the old rubber enough where it won't peal off and resists scratching:
On the top glued part where the glue remained, it's stuck pretty good, resists scratching, pealing and pulling. While the glue on the unstuck sides peals off easy.
It's a pass/fail. It came apart easy, leaving one side stuck in good while removing rubber from the other. The glued side has grabbed and is tough to scratch or break off, while the removed side lost its strength once pulled off, all of the glue on it is easier to remove. .
It wants to stick and may work well in your tires providing you create the right conditions for the glue to soak in enough to grab it. .
You couldn't just seam a tire together like stiches, but may be able coat the bindings and draw the rubber back over to seam it. And add an glued under lament (7-10" old cut piece of tire or?) to hold the bindings.
