ricobike
Today's task was to figure out why the builtin kickstand on my Schwinn Collegiate rider was wobbly and not holding the bike up very well. This bike had seen a lot of use in it's day so I figured that the spring on the kickstand was worn out. Since I don't normally work on Lightweights, I didn't have a replacement kickstand in the stash, so I proceeded to disassemble it to replace the spring with one from a donor kickstand. The Schwinn service manual (Vol 2) has a pretty good section on how to remove the spring. Here's a link to rustjunkies thread to the kickstand section:
http://thecabe.com/forum/threads/schwinn-service-manual-volume-2.81579/page-3#post-508130
I replaced the spring, and it still had the same problem. Kickstand would wobble up and down when in either the up or down position. Looking closer at it, I could see that the pin that holds the spring in place was worn and not engaging the cam correctly. I replaced that pin with the pin from my donor kickstand and voila, problem was solved. I have a few bikes with similar problems so I'm pretty sure it's a common problem, but I couldn't find anything about it in searching around. Hence this thread. Hopefully it will help anyone having the same issues.
