mike j
Have a few single tube tires 28x1 1/4 that aren't in bad shape. They all hold air for a little while, seems to be a fairly common situation. Was thinking of injecting slime or one of the other tire sealants, but non offered a permanent solution. Been using Permatex black super weatherstrip adhesive for crack repair & to replace a tire valve. The material adheres to rubber excellently. After trying w/out success a couple of reducers for the material, wound up with urethane enamel reducer (not for the faint hearted). Got it to the consistency of milk, injected it in the valve stem, first removing the valve, then spun the tire around. Made sure that it got the inner side walls, as that is where I believe most of the leaks were. Added some air to help get the material in the cracks. Added & removed air to stimulate drying, been four days & still holding air.
