Springer Fork assembly tricks?
Discussion in 'General Discussion About Old Bicycles' started by jjwithers, Jan 14, 2007.
  1. #1 Posted Jan 14, 2007
    Guest
    For some reason i have the hardest time assembling the springer forks on cruiser bikes. are there are tricks to putting them on the bike? Once i finally get them on, the spring is never at the proper angle as it points towards the rubber grommit and bolt head.
    In other words, Once that upper collar that goes around the neck is screwed down by the upper neck bolt, the angle of the sping is way off, not straight like i see in all the photos.
    what is the proper assembly procedure?
    thanks.
  2. #2 Posted Jan 14, 2007
    sam
    sam
    May 24, 2006
    1,319
    208
    set on the bike.Downward pressure on the frame puts the spring bolt in line.
  3. #3 Posted Jan 17, 2007
    Guest
    Springer Fork Assembly photo
    Here is a photo of it...
    [​IMG]
    Will it line up in time or is there something goofy here?
  4. #4 Posted Jan 17, 2007
    May 25, 2006
    214
    3
    springer difficulty
    Looks to me like your trying to put a boys( mens ) springer on a girls frame.Girls head tubes are generally longer therefore it throws off the geometry.
  5. #5 Posted Jan 17, 2007
    Guest
    very typical of the bike shop that sold it to me....
    thanks.
    Now i get to go and tell them they suck and try to get the correct one.... and i get the joys of re-assembling it (actually, that part i like. I don't like dealing with them).
    J
  6. #6 Posted Jan 17, 2007
    sam
    sam
    May 24, 2006
    1,319
    208
    That an't it--if it were a boys fork the steer tube would be too short.
    Try flipping the bracket you have on the steer tube .I think you have it up-side-down.Just take the bolt out flip the bracket and put the spring bolt back in.---sam
  7. #7 Posted Jan 17, 2007
    J.E
    J.E
    Guest
    Yep the bracket looks upside down
  8. #8 Posted Jan 17, 2007
    Guest
  9. #9 Posted Jan 18, 2007
    Riding a '37 Fleetwood
    May 22, 2006
    9,914
    2,980
    Lancaster, Ca.
    HI, it looks like your fork is the wrong size somewhere. my guess is that indeed the head tube is correct but the rest of the fork is for the shorter boys head tube. look at the photo I'm posting and notice how the 2 legs of the springer end up level with the top of the head tube, yours don't even come close. I'm guessing your fork, somehow, is made from some mixed parts and you should have whoever you got it from get you another one.
    Good Luck[​IMG]
    Scott:cool:
    [​IMG]
Loading...
