I was wondering about the same thing. I could pick it up for you Jkent when I go to Trexlertown Swap in the end of the month.
I'm no expert on washing machine motors, but I like the look of it with the twin cylinder. I think it would fit in your Motormaster frame.
I was also wondering whether it's a 2 cycle, or a 4 cycle? Maybe somebody else can chime in on it.
The problem with using a Magtag washing motor on a bicycle is there is no throttle control, only way you would have to control speed is by slipping the clutch if you built the bike with one!
correct me if I'm wrong but couldn't you change the Carb. The Maytag in the YouTube clip shows a Maytag engine and he says it has a bigger Carb on it.
Just change the carb to a throttle control carb and walla.
JKent
