Anybody know how to remove the fork lock mechanism so i can try and repair it i got the broken key out and made a new key. The cylinder turns but the pin doesnt move any help will be greatly apreciated thanks
I used this method but exchanged the hole drilled in center of the cap for a small edge slot cut with a Dremel mini cut disc (similar to a pop-off back a watch uses). But those instructions did help me fix my lock. It's not difficult to fix these so much as it is tight and somewhat delicate work.
