Block Chain Restoration
Wheeled Relics
how to turn a turkey into a golden goose
Before
After
*By following the instructions below this point you releAse me of all liability in cAse of personal injury or death!
Start with a crusty turkey
1. Solvent soak overnight (acetone or gas works) remove and allow solvent to evaporate
2. Submerge in simmering OA Bath and bring to low boil 3 min
3. Remove from OA ; submerge in solvent immediately to neutralize OA and prevent oxidizing
4. Use tooth brush to knock off any left over grunge if it looks good go immediate to step 6
5. Re submerge in simmering OA for 2 min bring to low boil again
6. Quench with solvent and then immediately submerge into in a tub of oil.
Your golden egg will soon be laid.
Ps- use a respirator that will filter organic vapor. Do not breath OA vapor. perform in ventilation and respirator rated for these vapors.
Solvent soaked and let dry (softened up)
Submerged in boiling OA
Yuck pull it out of here and put it back in solvent before it can oxidize (will turn green fast if it's nickel) it might be done here if not boil it again
When all the junk is off and u remove it from the OA ... Do not let it sit exposed to the air a quick rinse in the solvent then immediately into the oil
That chain would have taken meca month of work to look that good....and I would have washed the bluing down the drain.
Chain looks great Dave! I'm gonna have a tough time convincing the little lady about boiling Oxalic Acid on the stove though (not to mention the pets). How'd you convince Donja and your kitty?
