Dick Rath
Part needed: In disassembling the bottom bracket on my 1897 ladies Iver Johnson restoration project, I damaged, or more accurately, I broke into multiple pieces the right-hand-thread bearing cone. Being carefull not to apply too much heat on the cone for fear of altering its hardness and, given that there were no holes or notches for using a spanner to provide leverage, I decided to use a pipe (stilson) wrench on the cones knurled rim. BIG MISTAKE! So, pictured is the broken cone, along with a few showing the sprocket and crank shaft. The cone's thread diameter is approximately 5/8", slightly larger than the tread diameter on the other end of the shaft (for the left side bearing cone) so it can be slipped over those theads and on down the shaft. Obviosly the restoration project has come to a full stop until a replacement bearing cone can be found. Any help or leads would be most appreciated. Dick Rath
