1900 Melvin coaster 3-crown Frame ID
Ricker
Hello CABE-
I picked up a 3-crown TOC bike that I would love to identify. Mr Melvin received the patent for a coaster brake in 1900. This bike came from Mr Melvin's great grand daughter. The coaster is one of his, but I can't get it apart yet- it is attached to a Thor rear hub. It also has a Thor front hub and a Thor seat expander stamped pat pending. I believe the original color is light blue or robin's egg blue (paint remnants found) and the lug work is very distinctive. The lugs are on both sides of the tubing. Serial number is 807. The whole frame was nickel plated but I am not sure what was left exposed, looks like the crowns were so far.
The head badge holes are also very distinctive wrapping around the head tube and not horizontal to each other- photo has red lines around holes from back side of head tube. Photos:
Blue Streak
Here are two Melvin Coaster Brake ads from 1900 and two patents:
April 15, 1900 issue of The Saint Paul Globe (St Paul MN)
1453973
May 13, 1900 issue of The Saint Paul Globe (St Paul MN)
1453974
Charles H. Melvin Back Pedaling Brake Patent No. 648,971 (May 8, 1900)
1453975
1453976
1453977
1453978
1453979
1453980
Charles H. Melvin Back Pedaling Brake Patent No. 648,972 (May 8, 1900)
1453981
1453982
1453983
1453984
1453986
Ricker
Thank you very much for the fantastic information! I have been digging into the FM Smith connection and had run across the “gopher” but not the “summit”. The envelope I got with the bike has a few of the patent sheets but are poor scans so the high quality of yours will be really helpful with getting the rear hub apart to clean and make functional.
Melvin lived in the twin cities area so I suspect that he had a connection with FM Smith Bros since they sold the brake and there may be good odds that the bike came from their shop. The ads seem to put it right around 1900 so this is great- probably as much as I will be able to find short of a gopher or summit badge to see where the holes line up.
really great!
Rick
Blue Streak
Your frame's triple crown design and lugs look a lot like 1898 Manson (they changed lug design for 1899) but appears Manson did not have eccentric rear chain adjusters until 1900 and different frame details. Crankset looks like Fauber. Manson badge holes do not match yours. So probably not a Manson but a lot of similarities. Will keep looking.
March 1898:
1454062
1454061
April 1898:
1454063
April 1898:
1454064
December 1898 - Article about company making eccentric chain adjusters in Milwaukee:
1454065
1454066
January 1900 - Manson with eccentric chain adjuster although does not look exactly like yours:
1454067
1454068
September 1902 - Manson and Sherman Cycle Companies become part of Great Western Manufacturing:
1454069
October 1904 - Manson advertised with Thor hubs:
1454070
Ricker
I agree, I don't think it is a Manson. The early 3 crowns had a model with Fauber cranks and lugs that look similar in the ads but they don't have the eccentric. I haven't see the eccentric bottom bracket on the few Manson's on the internet, they always have the dropout eccentric or traditional slots- I have wondered if it was ever really done that way. I don't think it is a Fauber frame either - their lugs for the 3 crown were only on the outside and had a different pattern (according to the ads) and then later they had the 3 crown method shown in the ad above or possibly one that was two halves welded that incorporated the BB shell and then twisted 90 degrees (so the BB shell was perpendicular). That article also showed the stays as a part of the whole and not just a lug. I will try to find that article. My best guess is that it is a private label bike for the bike shop, so more of a jobber bike. The patent drawings are interesting since it looks like the artist used this frame in the drawings for the brake.
Blue Streak
With a little more digging I am going to go out on a limb and say your bicycle is a 1899-1900 Gopher Special made and sold by F. M. Smith & Bros. of St Paul MN. Gopher Bicycles were sold 1896-1902 (1902's may have been left over 1901 models).
F. M. Smith & Bros. also made and sold the Melvin Coaster Brake.
F. M. Smith stopped making bicycles late 1901, his wife sold off inventory in 1902, then one 1903 ad says a new company is making the Gopher, but nothing more after that.
The Gopher Bicycle logo is horizontal and may have translated into a badge that wrapped around the head tube and fastened on back side like your frame has.
Here are some references that to lead to the above conclusion:
April 1896 - Earliest ad found:
1454187
May 1896:
1454188
May 1897:
1454189
January 1898 - States F. M. Smith manufactured the Gopher Special:
1454190
March 1898:
1454191
April 1899:
1454192
April 1899:
1454193
May 1899 - Specifically discusses eccentric chain adjusters:
1454194
1454195
1454196
June 1899:
1454197
June 1899 - Star front sprocket:
1454199
1454198
June 1899 - Light blue colored Gopher Specials and F. M. Smith & Bros. new coaster brake:
1454201
April 1900
1454202
May 1900 - Gopher Bicycles and Melvin Coaster Brake in same ad:
1454203
May 1900 - Melvin Coaster Brake and Gopher Special light blue in same ad:
1454204
September 1900 - Melvin ad:
1454205
November 1901 - Smith our of business:
1454206
March 1902:
1454207
April 1902: Mrs. F. M. Smith now in charge:
1454208
March 1903:
1454212
Ricker
Wow! I am speechless at your finds!
I think your assumption is the most plausible, especially considering the light blue paint -
Thank you! When I have time to work on this bike I will post more photos.
Rick
Blue Streak
A couple final references for now:
December 1898 - Only 500 bicycles to be made in 1899 seems to make sense with your 807 serial number and thinking it is an 1899 model (this would mean they made 600-700 total for 1896-1898 which seems believable). F. M. Smith & Bros. appears to have been a small volume manufacturing company that sold mostly in the St Paul MN area:
1454272
1454273
March 1899:
1454274
1454275
January 1902:
1454276
January 1902:
1454277
