Everything is clean and lubricated so it’s time to glue the Robert Deans in place. I’ve lost track but these tires have been glued, removed and replaced three or four times now.
In a recent conversation with him he mentioned not to ride without positive air pressure in the tires! They ride “softer” without air and that’s what makes them great for display but the pressure prevents the tire from “walking“ around the rim, causing the glue to fail and eventually they walk enough to shear off the valve stem.
So now I’m im the habit of paying attention to tire pressure before heading out!
Beginning 180 degrees from the valve stem, I take four clothespins and remove the steel springs. Then I lift up the tire and insert 6-7 clothespin halves in line with the spokes ( since I avoid applying glue to the spoke nipples) between the rim and tire, rolling the tire partially off the rim in order to apply the cement.
The curvature of the clothespin that would normally grip the laundry allows the rim to seat in it, as a pivot point.
Now the tire can be rolled partially from the rim exposing the rim for easy gluing!
you can’t quite get 90 degrees glued at a time, but almost. Stop and check for centered alignment on the rim and that the valve stem is not badly crooked. Then move to your original starting point, working back to the valve stem and carefully checking alignment as you go.
When you are through the valve stem should have normalized back in perfect alignment with the rim. If not don’t panic. Working your way around the tire, lift a pull in the proper direction to center the valve stem in the rim. Then inflate in order to firmly set the glue.
Here I pulled out the inner pins so that the tire can be centered onto the rim slowly and carefully as it suspends the tire above the until you are satisfied with the alignment. So far this seems to be the least messy approach to cementing tubulars! It’s taking me about 30 minutes per tire to get it done now!
Also thanks to the CABEr that sold me this bicycle wrench! It was invaluable for removing the bearings and for disassembling the crank arms!
