1913 Pierce Project
Almost ready for the frame tubes to be brazed together! All tubes were clamped to each other once more, and the flanges were worked again for as tight a fit as possible.
It was also time to re-check frame angles.
So good, I like the old-school, and likely appropriate approach to using lead filler as a final application. Will you use tinning butter just prior to applying the lead?
