Bikermaniac
This bike started its life as a 19" frame Westfield Motorbike, however it has the same components as an 1916 or the early 1917 Indians: diamond cups, flat rear dropouts, bracket-screw chain adjusters, straight fender bridges, single crown fork with welded truss bases, separated trusses with thick washers, same cranks and pedals and one piece bottom bracket.
So I just changed the chain ring and the name plate and bum I'm half way to transform int into an Indian. Of course I need to locate the fenders and the tank to make it happen, not easy but I think I'm getting closer. I hope you like it. Thanks, Nelson.
Changes made:
Changes made:
