1921 Columbia ArchBar bottom bracket trouble.....
IngoMike
May 7, 2013
780
Sand City, Ca.
I was having trouble with a loose crank arm so I took my BB apart and found the drive side cup had shredded off in a few places, Hmmm. I thought that since the damage was only to the edge of the cup and not the bearing surface that it should be ok, but that is not the reality. Once I put everything back together and get a few miles from the house, the crank arms start loosening up and the problem resurfaces. These Columbia BB's are small, 1 5/8", anybody have some cups? This was my daily rider until the breakdown.
1228521
1228522
1228523
1228524
1228525
1228526
1228527
cyclingday
8,032
Costa Mesa, California. United States
Wow!
Pope definitely didn’t have a better idea there.
Looking at that two piece crank, sure helps to explain why the one piece crank was invented. Lol!
Sorry for the chuckle at your expense, but I just went through a similar experience with a Colson crank earlier this year.
We’ll all keep an eye out for that type/size bottom bracket for you.
Good luck!
Reactions: IngoMike
Archie Sturmer
1,542
Los Angeles, CA, USA
How (vs. how-well) do these 2-piece cranks actually work; (hope to avoid having to find out).
It looks like the cranks use a turn-buckle concept, where rotating (relative) the center sleeve tightens the 2 crank arms together.
Not sure what keeps the 2 arms tight to each other, (besides the sleeve threads); or what would cause the sleeve to loosen with riding.
However, the LHS jam nut looks to keep the bearings tight, (if the 2 arms also keep together).
The LHS crank is slotted, but I do not see a keyed washer?
GiovanniLiCalsi
4,216
Alameda, California
Nice basket!
Is that original or remake?
Looks similar to an Iver Johnson basket.
Riding an Alexander Rocket Bike
Sep 25, 2006
24,948
Boston, Massachusetts
thecabe.com
They are actually a three piece. There is a double nut inside that holds the crank arms together.
Reactions: bricycle
IngoMike
May 7, 2013
780
Sand City, Ca.
These first three photos are not mine, but they tell the complete story of the 3-piece crank...the last photo is my special tool set-up.
1228849
1228850
1228851
Here is my high tech solution to holding the collet to unscrew the crank arms.....
1228856
IngoMike
May 7, 2013
780
Sand City, Ca.
The Iver Johnson "Man Basket", an exact reproduction of the original by @ivrjhnsn, a really, really nice piece! I can get a lot done with this basket before I have to break out the CycleTruck. The basket has also saved me in the past, I felt a loose front end one day and found that the stem had broken just below the basket mount and probably would have given way if not for the basket. I might have to dial it back when riding this one......
1228866
1228867
1228868
1228869
1228870
Reactions: ivrjhnsn
Archie Sturmer
1,542
Maybe the stem (or replacement) could be inserted more fully into the fork; and maybe the basket bracket could be attached to the horizontal (whatdoyoucallit) offset member of the stem?
bleedingfingers
Mar 11, 2013
171
Regina, Canada
I just got my second similar basket but it attaches to 2 points on the handlebar
will hold 45 cans of beverages .
That would be hard on the stem for sure .
Maker unknown
Your everyday rider is super cool
Reactions: stezell
bleedingfingers
Mar 11, 2013
171
Regina, Canada
Not as many crossbars I think they were made specifically for Newspapers .
think you would have to put in a box to carry other stuff.
IngoMike
May 7, 2013
780
Sand City, Ca.
I think I hijacked my own thread by posting that basket picture! I know its a cool basket, but it is currently useless without a bottom bracket!
Anybody? I need a 1 5/8" bottom bracket cup!
