Still have it?
I will buy all of what you have shown for the JOHNSON MOTOR WHEEL. you can call me at 320-455-92064. Yes your missing a lot of parts. starting with the two engine supports to the rear axcel, two seat post brackets. crank shaft output shaft sprocket chain gurad,control levers , rear spider & sprocket with compression springs,chain, Axcel cap for engine shut off ground , Fence guard top & bottom, tea cup headlight, one gas tank bracket & rear rim clips spider sprocket springs.I just found a 1921 iver johnson bicycle engine carburator and gas tank and was wondering what these might be worth? I am totally new to the bicycle world.
I will post pix as soon as I can.
Any Information would be helpful,
Thank you,
Ken D
