1935 Colson Flyer
elginkid
I’ve had this for years, but I don’t think it ever had a proper introduction. It’s possibly the favorite ballooner in my collection. It’s black and cream, with gold pinstriping. In any case, thanks to @Boris I finally have the correct kickstand. I still need to tear down the headset and bottom bracket for a rebuild, and the seat is in desperate need of restoration. But I have done a couple of 20 mile rides on it.
Yes, good looking bike! I am a bit confused though as your lugged frame seems to be a pre-1933 28-er frame from Colson. I have never seen a lugged Colson frame later than 1933. Serial number should clear it up for sure.
I think the serial is 5A3057
It’s possible that perhaps the bicycle was “updated” in the 30s I suppose. The rear fender likely has enough clearance, the front fender might be a bit closer, although the fenders seem more of a balloon width. One thing that would potentially support that theory though is the lack of open drop outs on the front forks.
If it is meant to be a 28” bike, then I just bought the wrong kickstand, lol.
After another search it looks like the closed dropouts in 1935 wasn’t out of line, I wonder if the frame has to do with the frame size. I think every other motorbike I’ve seen from 1933 on for Colson has a shorter frame, at least that’s my guess based on the frame geometry. Maybe the tall frame models still used the lugged construction?
Very interesting. Something new regarding the 33-5 transition from 28 to 26. From the Colson serial number thread below.....measurements of chain stay length and fork length below for both wheel sizes from 1933. Colson was one of the few that did not use frame/fender spacers for 26" wheels but instead shortened the rear stays and fork to accept 26" wheels. Compare your frame to the below measurements for the two wheel sizes.....
You’ll have to pardon the drawing, I don’t have a proper scale, or a way to measure angles, other than by eyeball, and the bike is all together. But here’s my best attempt.
I did a search for 1935 Colsons to see if I could find another Motorbike with a tall frame. I found and old post on Rat Rod Bikes, with a serial number of 5L2294, so the end of the year as opposed to the beginning, but not only is the frame not lugged, but the rear stays are VERY different.
