Hello all,
Looking for a bit of help with a seat post and seat post bolt issue. My old Shelby has what I believe to be the original post bolt and there are several problems. My main concern is that the frame doesn’t close far enough to grab the seat post. I’m quite hesitant to crank on the bolt for fear that I’ll damage the frame. Over time it looks as though the tab that typically holds the bolt in place while you tighten is less than effective at keeping the bolt from turning. It appears that folks have attempted through the years to stop this turning by grabbing the now rounded bolt head. With these issues I’m quite happy to remove it and to replace with a similar bolt but the thing will not back out. It seems that this bolt is somehow kept in place by design or it simply has 1 or 2 threads that won’t grab on the way out and therefore it won’t back out. (The bolt isn’t perfectly straight either) Is there anyone out there who’s seen these issues before, please share your experience. I want to just cut the head off this bolt, but not sure if that’s the best way to go. Also, the frame measures right 7/8 but as stated a 13/16 post cannot be tightened. Months ago I tried a shim that should have remedied this and it did not. I was unable to get the post in at all with the 1/16” shim, so I’m not certain what’s going on here. I guess it can simply be chalked up to, this is a 90 year old bike.
