1938 BSA folding bike free wheel removal?
shawnatvintagespokes
May 11, 2015
102
126
Camas, Washington
#1
Hi, all,
I am restoring a 1938 BSA folding paratrooper bike. I have to remove the whole freewheel assembly to be able to replace spokes. I have the outer part off, which unscrewed clockwise, and now I am trying to remove the inner part. Does anyone know which direction it unscrews and/or have any removal hints?
Thanks.
Shawn
May 11, 2015
102
126
Camas, Washington
#3
Unfortunately, the notches on the freewheel are about 1.5" apart and I have never seen a freewheel removal with that large of a diameter. If you know of any, that would be great.
rustjunkie
Moderator
Staff member
Jul 11, 2012
13,200
17,855
Monrovia, CA 91016
www.rustjunkies.com
#4
If there are any near you: a really good, old bike shop probably has one. Phillips and Villiers freewheels were about that size IIRC. The tool was certainly produced, just gotta find one.
May 11, 2015
102
126
Camas, Washington
#5
Thought I would update this post with the solution I came up with in case anyone else has the same problem. I live at least 2 hours from a really good old bike shop so I had to be creative. The BSA freewheel has two notches 1 1/4" apart (inside measurement) and the notches are 1/4" wide. I found the Park FR6 tool, which has 4 prongs 1 1/4" apart, and 5/16" wide. I bought one and ground off two of the prongs, ground the prongs so they were a tad less wide, and made the notches in the freewheel a tad wider. It fit and it worked! The freewheel is off!
