Sold 1939-1940 ok original GREEN paint Western Flyer CWC 3 piece tank
225 shipped
RI
bikesnbuses
I stripped most of the red repaint off f this tank.. I DO have the long fastening/attaching screws
I believe it will still clean up more,I was using some Easy Off oven cleaner,scrub brush,palstic razor and hot water
This tank has no rot,some light rust.. and has obvious paint loss
Hard to find tank,especially with green paint still on it
1655718
1655719
1655720
1655721
1655722
1655723
ASKING $250 shipped via check, MO, PP/FF OR trade for/toward -/+/=$$ for
* Mens CWC Aluminum truss rods
* Prewar Shelby chainguard in heavily patinaed black paint
* Wise frame lock
1655726
Hoagie57
this is the hard to find tool box tank GLWTS !!!
I don't know if you'd call it a "Tool Box" tank. I'm most likely wrong but when you undo the 2 screws doesn't the complete come off. Not just the insert or can you pop that off when the tanks fully mounted? 🤷‍♂️
mrg
Panel can be removed with tank staying in place some so you could replace the batteries without removing the tank ( battery tray hooked to the Panel ) but no battery models can be used for storage, I put wing nut/screws on mine, fit a tube, tools, pump & water!
skiptooth
it may not come off ? mine looks the same but side cover comes off ! for storage ! your trailer looks great! btw.. my trailer pic's should be acc? on the cabe but not sure? also search pismo coast village vintage trailer rally in the month of may of each year! Richard
skiptooth
in the picture' s 6th one down looks like its coming off. and ad says 3 pic tank ..
