Pedals Past
1939 Ford kit tear drop trailer, i have owned this over 20 years it is titled spcns 2000 following restore, reskinned aluminum, has a 1/2 ton elec disc brake axle reinforced frame with extended 1-7/8” ball tongue. New 5 gal horz propane tank 9 gal propane hot water heater outdoor shower with curtain inclisure teak floor grate, large mahogoney tongue mounted Handuras mahogany wood storeage box with battery bank space for 225 amp hour dual 6 volt or 2- group 31 deep cycle 12 volt system with built in marine charger and in place useable portapotty with tank and fresh water flush floor is teak and holly inlay propane 120/12 volt refer, propane dual burner stove top polished sink with removeable hand held h/c faucet in one piece 24” wide 48” long Haunduras mahogany counter top diamond tuck polished aluminum back splash built in teak cup holders mahogany food storeage boxes inside walls and sides are original 1939 marine plywood bleach stained chris craft blond. Ford hubcaps on ww tires has builtnin dvd cd tv with isolation switched power amp marine power antennae. Solar roof top vent polished brass clam shell 12 vdc lights large surf board mirror teak cup holders upholstery is 1950’s Hawaiian print cushions sleeps 2 people 6’ your legs go along side refer box with food storeage removed outdoor fixed lighting. Marine tin coated copper wiring with fuse panel. You wont find a nicer get more looks trailer has won many car shows. Tows like a dream $8500.00 firm over $25k invested will deliver for $500 anywhere in Northern or Southern California, Reno or up to Grants Pass oregon with advanced payment. Cashiers check or cash only will take up to 3-$3000 payments over 60 day period if that helps out (excludes tge $500 delivery $500 added for inside storeage to hold) Clear California title and registration is current. Pm or email [email protected] for info or call me (707) 246-8133. See photos
1966 21 window bus 2110 motor and freeway flyer type 3 transaxle adjustable beam pulls it to Tahoe is available new sumbrella seats and Mercedes canvas sun roof upholstery BT power amp stereo Gene Berg locking transmission pm to inquire
This available 1957 VW single cab custom roof rack 3 battery system 1641 motor with freeway flyer big nut gear reduction boxes will do 80 mph pulls trailer at 65, performs well formerly known in hobby as the Elton John Band Truck purchased from deseased sound mans family thru Cokacola co. Big BT retro radio/stereo with power amp switched out door Bose marine speakers outdoor bed and treasure chest lighting. PM to inquire.
