I might experiment on this one on dulling the clear. Going to try rubbing compound first and if that doesn't work going with a scotch bright pad. I will be ready for ann arbor just not sure I want to take it up there.
Nate a good product to use that the body shops use for blending clear over existing clear like on a roof post is a extra fine white scotch brite pad barely leaves super fine scratches in conjunction with a creme callled blend prep which you can get in different grits as well and you can buy these at autobody supply shops then you can use compound to get your specific shine back. Good luck
Some states Ohio being one I believe that laquer based paint can't be purchased in the state since it is toxic. I believe you can still get it in Michigan.
It took somebody who probably went painting without a mask on to get these laws passed. Another problem that I run into are the paints on middleweight bikes of the 50s and 60s. They almost have a metallic look to them, so I'm sure I'll have to get crafty trying to replicate the look.
