Hi
@Jewelman13 (and Thanks to
@GTs58 )
Very nice bike, and the serial number lack is a real oddity.
K9 means the frame was made September 1943. At that point, Westfield were building up bikes almost immediately, so the serial number should have been in the W16xxxx region. See my listof known survivors below.
Actually, it's a little odd that I have no bicycles from the W16xxxx ten thousand block listed, I normally have at least two or three. That is probably just a coincidence.
The frames when made were stamped with the date code into the bare steel. The serial number was stamped after the frame was painted (ie, during or after assembly), so somehow this was not serialled after production.
It's not a replacement frame, since these too were serial numbered.
Either there was an error, and it got through the stamping room without being stamped (first I've seen),.
Or it 'fell off the back of a lorry' (as we say in the UK). See also Johnny Cash...
Or (since it's very nice, and has all the pinstriping, etc), it's some form of display/sales piece for Westfield, so wasn't serial numbered since it was for internal use.
Or (most likely) there's another reason I've not thought of (-:
Anyway, here's the closest I know of: W171566 :
https://thecabe.com/forum/threads/bike-with-funny-little-front-fender.170440/
There is a good similar but later example linked in it.
Best Regards,
Adrian
