1945 Westfield bicycle paint preservation and wax to use
Pvtryanww2
What would you use to protect original paint on 1945 Westfield Columbia bike
TequilaMockingbird
If you don’t want to clear coat it (and I’ve seen that done) you could use some paste wax if the surface is smooth or liquid/spray wax if it’s rough. Another thing I’ve seen done is giving it a rub down with boiled linseed oil. Should dry enough not to remain sticky and it can be removed with detergent and water (and elbow grease. ) I’ve also heard of using a rag and old motor oil. I’ve never done anything but wax and that’s nice because it’ll eventually wear off or can be washed off so there’s no commitment like if you clear coated the patina.
49autocycledeluxe
clear coat and linseed oil do not "protect" paint on old bikes. proper storage protects the paint. if you want to make that bike shine again there are many different ways to do that. once it is shiny, then you can wax it if you want, but since hopefully the bike will never spend time in a damp conditions our outside you would not even need to do that.
Actually BLO will protect the paint to a certain extent. It has a natural resin. Clean and polish off the oxidized paint and then wax or coat with BLO. Neither one is permanent.
