1948 Monark sex change?????
Pauliemon
Dec 22, 2009
496
Sacramento, California
My buddy Curtis and I enter the bicycle portion of the Sacramento Autorama almost every year since 2010. This year we decided to do a TRM convertible tank on a 48 Monark Deluxe. I figured I wouldn't ruffle to many feathers because it was a girlie.
I went through the standard amount of parts switch/mock ups,...lots.
We ended up dropping the skirts. We thought they interrupted the lines.
Now the fun stuff. Curtis is a very talented fabricator, he did all the fab work. He's great to work with. "Hey Curtis lets put a bracket on the chainstay so we don't have to use a strap", "okay".
We cut up a repo horn tank to place under the TRM tank
Removed the bottom support bar for a cleaner look.
Pauliemon
Dec 22, 2009
496
We didn't want a rack on the back but liked the ribbed design. So we joined it with the chain guard.
We had to weld the chainring to the cranks so to remove the pin that holds it. Also I used modern wider one piece cranks and sweet heart chainring.
Pauliemon
Dec 22, 2009
496
I used later model Monark double deep fenders. I wanted the wheels to disappear in the fenders. Curt lengthen the rear using a piece of the stock rear fender. He also removed the indentations for the front fork legs and rear taillight. The taillight is a Persons multi with the lens replaced with a 53 Chevy lens.
Pauliemon
Dec 22, 2009
496
I think the saddle is a 1930s Persons. I took the cover off a $35 cruiser saddle. It was a single pan saddle so I modified a bottom pan from a dual pan Messinger saddle. That way it was easier to stretch the cover and make it conform.
