1949 Huffman….
Phrank Vee
Hey Cabers! Looking for some advice. I’ve been “off of bikes” for about 8 months. I just had a relapse. I’m attempting to reassemble the lower bracket. I have tried 3 diff sets of bearing cups. Finally I think iI have the correct ones and the “Race” (not sure if thats the correct term)? Is tightning too far inside the crank. The bearing, washer, and nut, are correct and fit. Its just doesn't look right. Any suggestions? Thanks for your time.
J-wagon
Wow. Those deep cups. Possible to remove crank and show pics of race, bearings and view of cups?
Also, cup doesn't look flush to BB from pic.
PapaPengin
Maybe a dumb question, but
are the bearings inside the cups?
Archie Sturmer
Typical bottom bracket crank hanger hardware usually consists of 4 pieces on the right: cup, cone, bearing set, spacer washer; and 5 pieces on the left: cup, cone, bearing set, keyed washer, and lock nut.
Ball bearing sets should be 5/16” x 10.
The proper terms are cup & cone; upper races and lower races are sometimes seen in loose-bearings headsets on English bicycles.
Phrank Vee
Thanks for the reply. You inspired me to use my brain. I figured it out.
The “bell of shame” has been ringing in my head! My bike building privileges should be revoked!
Phrank Vee
The proper terms are cup & cone; upper races and lower races are sometimes seen in English bicycle loose-bearings headsets.
Phrank Vee
Take that apart and post pictures of all the parts. It is definitely not right.
