prewarmachine
A color combo you don't often see. Factory gray with dark blue claws.
Paint on the frame is solid and should clean up a bit more.
Rear fender blue is holding up pretty well, but the front fender has some paint loss and rust as you can see in the photos. Only a couple shallow dents that should come out easy.
S2 Wheels should clean up a bit and be presentable with the rest of the patina on the bike.
Never had the guard as long as I've owned it, but it still has its locking blade fork (working), motorbike grips, and factory riveted Schwinn stimsonite deluxe reflector. Reflector has some minor scratches, but is not broken.
I have had this apart. Hardware will come loose. Bearings/races look like they are good to go with an easy clean and grease.
Picture of the serial to come.
Feel free to ask any questions!
