absent brake levers were likely to have been Fratelli Pietra three hundred serie fellers:
slightly odd that such a brake system would not have had a quick release mechanism
this is sometimes seen where the cycle maker does it as an economy measure
alternately, the levers could have been from another maker who did models with lever-mounted quick release such as Balilla or Weinmann
the Balilla Corsa 61 model lever
chainset -
reason for fitment of the present UNIVERSEL set from the maker A. Duprat is likely to have been a quest for lower gearing
the ex-works set is probable to have been a three-arm 116BCD one fitted with a six-bolt chainwheel set, whether with or without Y-adaptors
most probable makers are Magistroni and Way-Assauto; other possibles include Agrati, Gnutti & Fratelli Brivo
with the six-bolt pattern the smallest inner which can be fitted is 43T whereas with the present set the smallest inner which can be fitted is 36T
current UNIVERSEL set -
presence of the cycle's current long-arm rear mech would fit right in with an owner's wish for lower gear range
bicycle a most excellent find in such good paint and plating condition for its 55-60 year age
enjoy it and husband it well
