1950 Phantom disassembly
50 Phantom Newbie
36
55
Sacramento, Ca
First of all I wanted to ask, was it common to have the year stamped next to the serial number on the crank housing. Just curious.
What is the best way to safely remove the bearing cups without scuffing or damaging them?
How do I remove the kickstand. I see a pin on the housing.
Sep 2, 2012
12,944
Central Arizona
That other number stamping is not part of Schwinn's serial number and was stamped later. Someones personal i.d. number maybe.
50 Phantom Newbie
36
55
Sacramento, Ca
The other number, 50, which is the year of the bike according to the serial numver, has a diamond shape I’ve seen on other Schwinn parts next to it
Sep 2, 2012
12,944
Central Arizona
I've seen that diamond stamped on quite a few Schwinn frames but there were no other numbers stamped. That stamping was done after the serial number was stamped, it's hand stamped and was done after the frame was painted. If that stamping is what I think it is, the #50 may be an indication of the year. Check out the last few posts in this thread. https://thecabe.com/forum/threads/schwinn-cruiser-5-300.125042/page-2
Reactions: 50 Phantom Newbie
Sep 2, 2012
12,944
Central Arizona
I came across a thread a while back when looking for info on the war time New Worlds. This is a 1942 NW that has the diamonds with the possible year in between. It would be cool if someone could shed any light on these diamond stampings. It wasn't a normal stamping but they do show up now and then. It must signify something if Schwinn actually did the stamping. @detroitbike was going to look into this but haven't heard back on the subject.
50 Phantom Newbie
36
55
Sacramento, Ca
I think the 50 is a factory stamping because it’s next to the diamond. Also, because the numbers look like it was made with a die rather than a crude engraving
PCHiggin
4,032
Ryderwood, United States
Schwinn and Electra made special tools for their built in kickstands, Park Tools made a version as well. They pop up on ebay. I have the Schwinn version (The Electra brand is identical) and used it countless times. Theyre pricey and if you only need a tool for this bike, do a search on kickstand removal. Ive seen other ways of removing/installing them without the special tool on this site.
