cottagethyme
Seeking advice for my modified front end. I acquired a beehive compression front fork but missing truss rods (spring mounts on top of supporting structure). The stem is a standard 7 1/4" and it seems to fit my 1950 Schwinn straight bar frame. I am not sure of the Schwinn model - balloon frame and was painted all navy blue. I'm looking for truss rods that will fit. I believe the distance from the stem bracket position to the truss rod hole near the axle to be 22 1/4". I believe most Hawthorne rounded truss rods are a little longer. I suspect the "7" shaped truss rods will work. I'm trying to stay clear of the beehive so thought I should go with a Hawthorne vs the Schwinn. Anyone have a source or input. Thanks!
