1951 Rudge Aero Clubman #125
wrongway
1,051
303
Pella, IA
#21
Can the Rudge experts explain how it is that some examples receive the hand chainwheel and some not?
Does it have more to do with quality level or with when manufactured?
Have no knowledge of the marque, hence this silly question.
Thanks for any information.
I have no idea and it is a good question. I have a 1947 Rudge Whitworth with full chaincase. It has the Hand Of Ulster chain ring and you would never see it except during maintenance. I also had a '59 Rudge with the very plain chainring. The one on this '51 is a 2 piece chain ring.
Likes: juvela
wrongway
1,051
303
Pella, IA
#22
Yes, the bars were bare above the brake levers (and your levers appear to be located lower on the drops than usual). As far as grips - I will defer to someone with more knowledge, but if it were mine I would just tape the lower ends with 2 or 3 wraps of cotton.
Here is where they are now. Pretty comfortable. Look more normal?
juvela
Aug 2, 2014
763
1,069
Playa del Rey, United States
#25
Thanks so much for the response! ;)
Have never seen a Hand of Ulster chainset where the chainwheel was removable. Do such exist?
Perhaps it was the case that top quality models such as this with the Reynolds tubing and Williams C34 chainset with its replaceable chainwheel did not receive the hand.
Finished project looks "just right" - congratulations on a fine job. :smile:
Those mudguards you located have the perfect look for the machine.
Reynolds question for the experts -
Noticed that the cycle's tubing transfer proclaims plain gauge tubing including blades and stays. It seems that this tubeset disappeared (was withdrawn?) at some point. Many frames were produced in Britain and France during the '60's and '70's with the three main tubes 531 plain gauge but never saw any from that era with this transfer. Am I in error to think the set must have been withdrawn at some point?
Your locus: "So now ah knowz whar all o' them winderz ah seez on houses har in Californie comz frumm!"
wrongway
1,051
303
Pella, IA
#27
Noticed that the cycle's tubing transfer proclaims plain gauge tubing including blades and stays. It seems that this tubeset disappeared (was withdrawn?) at some point. Many frames were produced in Britain and France during the '60's and '70's with the three main tubes plain gauge but never saw any from that era with this transfer. Am I in error to think the set must have been withdrawn at some point?
I don't know if they made a two piece chain ring for the Hand Of Ulster.
Thanks for the kind compliments.
juvela
Aug 2, 2014
763
1,069
#29
Fork crown appears to wear a partial chrome plated sheet steel cap.
If this were removed during the course of disassembly/cleaning the crown's surface beneath the cap would have provided a good clue as to the original colour prior to weathering.
Did you record an image of this?
There is a dark line on the downtube right where it enters the shell on the non-drive side. Hope this be simply dirt or a scratch and not a crack.
sam
1,452
448
San Antonio, United States
#30
Paint on these bikes is very thin. If you try and "bring back the shine" You'll take the color off. Clean it good with mild soap & water. Then I'd try a past wax. The decals should be coated but again caution is advised. Copal oil varnish should be used but you no longer can buy it
Likes: wrongway
wrongway
1,051
303
Pella, IA
#32
I was not able to get the crown off. I tried, but decided to pick my battles and not risk bending it. I did see under the shifter cable clamp the true color. Absolutely beautiful! Good eye....I'll check on that possible crack tonight.
juvela
Aug 2, 2014
763
1,069
#33
Thanks for the response.
You did a thoroughly wonderful job with the bike.
Not attempting to suggest any changes.
One would need a fork crown racer remover in their tool kit in order to access the cap.
Just a possible idea to advance the investigation... :wink:
Likes: wrongway
wrongway
1,051
303
Pella, IA
#34
Thank you! I am always curious when I get into a bike to see what the steer tube color looks like. I figure that is probably the true color. I was quite surprised when I got rid of a '59 Rudge (small frame) bike. I believe it was originally red, but had been sprayed blue. I salvaged the headbadge and under that was the shiniest, smoothest black paint I'd ever seen! Odd.
Here is the best example of the orange I could find under the cable clamps.
Likes: juvela
juvela
Aug 2, 2014
763
1,069
#35
Thanks so much.
On my monitor the colour looks as though it might be described as an orange-gold-copper flambouyant...but then am an oldtimer with imperfect vision. :blush:
Member @sam 's post about all Rudges receiving a black under/base coast would explain mark seen down by bottom bracket shell.
juvela
Aug 2, 2014
763
1,069
#37
Thanks so much for sharing this great resource! :)
Greatly appreciated.
wrongway
1,051
303
Pella, IA
#38
That's neat to see! I have looked at H Lloyd's and see that I can actually buy the decals and I could probably get close to the paint color, BUT don't worry as I don't plan on it. If you notice my bike does not have wing nuts or an AC hub. I read somewhere that means it's an export model. It has a 1951 S/A AW hub with chrome plated steel shell. I though that was wrong, but apparently not. It's fairly all stock except for the saddle and fenders. Mine is the 22" frame. I prefer the 23", but it's not too bad. The gearing is 46x17. Stock? Maybe. I took it on a brief trail ride and was able to max out at 18.9mph and averaged 13.9. Not bad for me!
sam
1,452
448
#39
does the S/A hub have a threaded driver or the three pin and lock ring?
