1952 Schwinn Hornet Marin-ish/Casual-ish style Klunker build
sunvalleylaw
Hi, I'm a new guy and this is my first project. I started over at RatRod, but started shopping over here so figured I would also join. Always wanted to do some Klunker build, maybe kinda like the Marin bikes, particularly similar to one of Gary Fisher's (though I am not worried about being pre-war) and kinda like, meaning close enough and not exact. But also, kinda want to keep a more vintage vibe, and maybe use the original fenders when it is wet. The use will be easy cruising around town with maybe some easy dirt cruising/klunking on the nearby dirt roads and easy near town trails. Here is my platform.
Here is the inspiration, one of Gary Fisher's '40's bikes, in this photo from Charlie Kelly's book:
My current thoughts are that I'm not going to use the skip tooth, and will probably use a 36t cloverleaf the seller has. Any of these original parts will be saved in case I want to put it back to stock, or if after using it a while, I am sure I want to keep it as a Klunker, I may pass them on to others looking for parts for a more stock restoration.
In the rear, was thinking about trying to affix a 1x9 or so derailleur (was thinking just getting a modern Deore) with an emergency hanger, but don't really think I want to have to bend the frame to fit a MTB hub. I am picking up some S/A drum brake hubs here from @frampton Will probably use repro Honda brake levers. I am also figuring that as long as I keep it a 1x, I can still use the chainguard, which I think I will do for now. Will have to see if I need something in there as a chainguide and if so, would like to fit it under the chainguard.
Will use newer tires. Probably Rene Herse or some WTB's that roll on pavement well but can go on a gravel road or easy trail. Won't do any hard core mountainbiking or even longer gravel rides on this. I have modern bikes for that. A little klunking around town that may include some dirt will be about what it will see.
Will likely just use the current fork, stem and handlebar. May replace the grips. Will use a plain Jane thumb shifter. Not sure if I will use big block style old pedals or just throw on some flats I have. I may leave fenders when it is wet and pull them as summer comes on in earnest. Will play around with that. As said, will keep the old parts I don't use.
Will probably find a Brooks saddle to put on and keep that old messenger saddle or sell it.
I will get a period correct head badge of some kind after looking for a while. And I will keep the Patina, though I may protect it and brighten it with some clear wipeable poly as I saw a guy do on the same paint scheme in a youtube vid somewhere.
This is all in the contemplative/planning stage. Will go pick up the bike in Portland in a week or three.
Give me any and all thoughts and advice for me to consider. Thanks for letting me join!
Cheers,
Steve
sunvalleylaw
Got myself a Brooks B72 from eBay that looks serviceable and will fit in with the patina. And have brakes coming too. Parts are coming together. Now I need to find my 70's Honda style brake levers and decide on a derailleur and shifter,.
Won the auction for these, at less than the cost of two of the ovals, and so can have some rotating head badges to fit my mood. I don't really care if I am not period correct (the ovals would be). Excited to put on that Speedway one.
In your pics of the bike you'll be using for your build I can see two dots on the head tube, possibly holes for the head badge. Looks like none of these badges have the same hole spacing as the large oval that was used from 1950 thru 1960, except for maybe the Speedway badge.
sunvalleylaw
Ok. Oh well first mistake. Had to make one sometime. Maybe something will work.
