Sold 1953 Schwinn B6
Danville, PA
dave laidacker
1953 Schwinn B6 - This is a very good looking bike with a lot of good aspects. However, the kickstand bracket which is attached/welded to the frame is messed up. So with that said I needed to initiate the advertisement with that issue. I will sell it as it sits or I will be parting it out.
  • The wheels are nice and run true and I just cleaned and redone both hubs.
  • The front fender is glossy and straight and the light tray is real nice and the light works. The hole at the top of the fender where the fork bolt goes through the fender was worn oversize with several small sheet metal cracks. I addressed that issue and it now it's not an issue. Probably stronger then new.
  • The rear fender is glossy and straight.
  • The tank is real nice and straight with no rust. The was some surface rust starting but I cleaned that up and put a light coat of oil on it. the battery holder of the horn was rusty so I cut away the rust , oiled it and it is good and holds batteries tight. I got juice to the button but its not going to the horn.
  • The springer has the lock and works well.
  • Rear carrier is straight.
  • The seat is nice.
As you can see all components are nice except for the kick stand bracket.
If you are interested in the bike as a whole its $1100.00 plus shipping. I think parts will bring more then $1100.00. I am going to give it a couple days to see if anyone is interested, if not it will be parted out.
Thank you
Dave
1534588
1534589
1534590
1534591
1534592
1534593
1534594
1534595
1534596
1534597
1534598
