firm also produced a great many pedal cycles and mopeds under the banner HWE, standing for Heidemann Werke Einbeck
https://mo-ped.se/werke/hwe.htm
bit of history here, scroll down -
Heidemann "Vespa style" juvenile bicycle -
chainset is Thun
crank removal tool -
both VAR and ELDI produced tools for crank arm removal where no threads are present
the VAR one is model #932
as recalled, they employ gear puller type articulated arms
spent a few minutes checking online without being able to locate any good images
AFAIK the VAR was discontinued some years back
here is an ELDI model designed for use with cottered chainsets, IIRC a similar model intended for unthreaded cotterless sets was also offered -
a quick and easy way to get them off is to employ the straight end of a large pry bar/crow bar; put a piece of latigo, or several layers of duct tape, around the blade and use the bottom bracket cup as a fulcrum
everything is made of steel with plenty of "meat" so no worries regarding deformation
appreciate it sounds crude; have successfully done them in this manner
