1955 BLUE Radiobike Restoration
Discussion in 'Project Rides' started by partsguy, Apr 27, 2017.
  1. #81 Posted Aug 11, 2017
    Sep 1, 2010
    6,390
    4,339
    Elysium Fields
    I had a Columbia 3-Star mens Deluxe.
    The original “blue" color was a little similar to yours.
    It was not a solid blue, but more like a metallic or iridescent hue.
    Scribble and partsguy like this.
  2. #82 Posted Aug 11, 2017
    Aug 13, 2008
    10,209
    3,788
    The Land of Oz
    Hard to say if the paint is just really faded in those areas, or very light, thus exposing the silver bonderized primer. The sheet metal parts were stored in an attic, away from the elements. They are a bright, darker blue. It's all the same hue and shade throughout, very consistent.
    Now, Scott M. owns the other known complete blue Radiobike. Any others I have been told about were rumors, and parts and pieces at that. Here is Scott's bike for comparison versus mine before restoration began. Well, now that I look at them side-by-side, I suppose the sheet metal parts on mine could very well be that bright, almost a sky blue color.
    In any case, I would prefer to only respray the frame and fork, and leave the parts alone, since they survived reasonably well. What say you, Dr. Jakes?? @2jakes
    Another reason I choose to leave the parts alone, is because their decals are not reproduced. correct decals for green and blue bikes are not reproduced. I would consider doing them, but I believe so few are left needing them it may not be worth investing in.
    17630127_908541795954679_5816121981524917982_n.jpg 17757536_908526369289555_4725706715175506058_n.jpg
    Scribble likes this.
  3. #83 Posted Aug 11, 2017
    Sep 1, 2010
    6,390
    4,339
    Elysium Fields
    I like the idea! Keep the parts as original as possible,
    If I had the chance I would go for the unrestored
    “as-is’” original over a restored one....anytime!
    What year is the Radio-bike?
    I have a ‘55 Red Phantom.
    The red color is a “metalic” hue (not sure what the correct term is)
    If I’m not mistaken, I believe the earlier red phantoms came with a solid red.
    I’m not an expert, this is only what I have read or seen.
    In the mid 50s...irisdescent or metallic colors were popular.
    This is mostly speculation.
    #83 2jakes, Aug 11, 2017
  4. #84 Posted Aug 11, 2017
    Aug 13, 2008
    10,209
    3,788
    The Land of Oz
    'Ole blue is a '55. The Radiobikes were painted using candy colors. The metal was polished, "bonderized" and a silver coat of primer applied. Then, a colored, yet somewhat translucent coat of paint would be sprayed. This gave the bike a metallic look. Most of the paint on the chassis of this bike is spotted from moisture and corrosion seeping into that bonderized primer, and making it appear discolored. In many areas, the paint was gone and the rust got to the surface, hence the bare metal.
    I now am in a flustered hurry to get these re-sprayed properly and have the rear rim back from the platter in time...my only weak links in this entire build. In order to get this done right, I may have to farm it out - I won't have the time during the week. It must be a person or shop I trust.
    Anywho, this painting process was popular in the 50s and 60s, but the effects of age are the same. Here is a 1968-69 Hot Wheel that was painted with this process, with similar side effects. Note the discolored spots on the side:
    2jakes likes this.
  5. #85 Posted Aug 11, 2017
    Sep 1, 2010
    6,390
    4,339
    Elysium Fields
    I was going to mention that creating the “candy colors” requires a
    specific method.
    But I see that you know what is involved.
  6. #86 Posted Aug 14, 2017
    Aug 13, 2008
    10,209
    3,788
    The Land of Oz
    The best classic restoration shop in the state is quoting me on the repaint. This shop has done cars, bikes, motorcycles, and trucks. The mashed kickstand mounting tubes will also be fixed or replaced while its in the shop. They do amazing work. We'll see....good thing I do not plan to ever sell this LOL
    Nope...not satisfied with a half nude frame...you guys were right about the paint being gone, but I had to try!
    edited.jpg 20170812_114852.jpg 20170812_114908.jpg 20170812_114920.jpg 20170812_114957.jpg 20170812_114942.jpg
    #86 partsguy, Aug 14, 2017
  7. #87 Posted Aug 14, 2017
    Feb 6, 2012
    2,632
    1,136
    Earth
    We know that half-nude frames work for some things, but NOT bikes. KEEP GOING!
  8. #88 Posted Aug 15, 2017
    Jul 14, 2009
    14,314
    13,245
    Evans, GA
    Actually I believe Hot Wheels were zinc plated--not silver primed and the color shot right over the zinc. People restore Hot Wheels too and I believe this is the process they use. V/r Shawn
    partsguy likes this.
  9. #89 Posted Aug 15, 2017
    Aug 13, 2008
    10,209
    3,788
    The Land of Oz
    I am a bit rusty, as I have not been very active in collecting Hot Wheels for a long time. However, I believe you are correct. If memory serves, the body was polished, and a very thin coating of zinc was applied in a tumbler. The zinc was cleaned and polished again, and a layer of translucent candy color paint was applied. This paint was discontinued after the 1972 model year, due to increasing cost, the economy, and the rising concern of lead paint in consumer products.
    The idea is the same though, with a similar end result.
  10. #90 Posted Aug 18, 2017
    Aug 13, 2008
    10,209
    3,788
    The Land of Oz
    Update:
    I got the radio back from the shop again. It appears the speaker probably went out, as a new one was retrofitted in the tank, using the old transformer. I will test it again this weekend. I am sure other components were replaced.
    As for the repaint, the restoration shop is unable to commit to the due date, and I am unable to find or think of anyone else local to do it. I can repaint it, but the tubes where the kickstand mounts need to be repaired or replaced while the bike is stripped. I do not know how nor own the tools to do brazing. So, in short, I may have to do my best and present it with the half-nude frame. I am not going to half-ass a paint job on a high end bike. I will still have this particular shop do the work, but it will have to be during the winter, after the show. I will not compromise quality over convenience.
    56 Vette likes this.
  11. #91 Posted Aug 19, 2017
    Nov 21, 2014
    641
    686
    Arcadia Ohio
    Looking good, and stick to your guns!! You are the right guy to bring this bike back to its former glory and to help out all the other Radio Bike guys do the same! Joe
    partsguy and 2jakes like this.
  12. #92 Posted Aug 19, 2017
    Feb 6, 2012
    2,632
    1,136
    Earth
    What is your tube lineup, and have you checked for leaky or dried up electrolytic capacitors etc? Is there a schematic for the radio?
  13. #93 Posted Aug 21, 2017
    Aug 13, 2008
    10,209
    3,788
    The Land of Oz
    There is a hand-drawn schematic by the founders of Yellow Springs Instrument Co. floating around from 1990. There was a schematic in the tank of every bike produced, but many have degraded from age and are not reproduced. I am currently having new ones made by a local shop, using an original I carefully removed from the red bike. My prototype knob is still being made. I have found a supplier for most of the antenna parts - a couple pieces are eluding me. May need to make them by hand, but I am just so short on time with trying to get my own bikes done.
    On a positive note, I have now offered my 1964-70 ornament fins on eBay. So far, people really like them. Lots of polishing involved with those suckers, but I love doing it. Shipped another pair of 'em on Saturday.
    But to answer your question, I outsourced the majority of the radio chassis repair to Tom's Antique Radio in Dayton. I love tinkering with small electronics, but this time I went with a professional due to time and more accurate repairs. He does great work for me and my friends. I will be sending two of my radios to him next month. My '58 Philco needs repaired as it never worked and I am unfamiliar with the early transistor units. My '41 Crosley needs a tune up and possibly a re-cap beyond my capabilities as well.
  14. #94 Posted Aug 21, 2017
    Aug 13, 2008
    10,209
    3,788
    The Land of Oz
    These radios are cool, but niche items, even in 1955-58. These are three-tube units, with a range of 100 miles if everything is good, including the weather. Three tube radios were never intended to be high end audio in any capacity. Radios with five tubes or more produced better sound quality, more precise tuning, and a much longer range of reception. Still, during the golden years of rock-and-roll, the Radiobike became a memorable piece of Americana because of it's unique design.
    During this period, early transistor "pocket" radios were arriving on the market. You could fit them in your pocket or belt buckle, or some had a small case you could put over your shoulder. Cars could have 45rpm record players installed from the dealer. In 1958, General Motors had an optional radio in vehicles that was removable. Portable radios were still selling. For the first time, not only could you own a piece of music, but you could take it with you where ever you went and listen to it. Radio manufacturers had their own unique designs, they wanted their product to stand out at every outing you went on. The Radiobike allowed kids and young adults the chance to take their music with them on their bike. Decades before even the Sony Walkman debuted in the 1970s.
    #94 partsguy, Aug 21, 2017
  15. #95 Posted Aug 21, 2017
    Aug 13, 2008
    10,209
    3,788
    The Land of Oz
    Back to what I need to do!
  16. #96 Posted Aug 21, 2017
    Aug 13, 2008
    10,209
    3,788
    The Land of Oz
    Thank you for the kind words, Joe!
  17. #97 Posted Aug 23, 2017
    Aug 13, 2008
    10,209
    3,788
    The Land of Oz
    Not sure I understand the reference? I have been pondering ever since this was posted.
  18. #98 Posted Aug 23, 2017
    Feb 6, 2012
    2,632
    1,136
    Earth
    I figured it out...RS still sells parts in the mail. Actually they are trying to pare down considerably and also suing the former owners (Sprint etc.) for basically screwing it up...long story.
    Allied survived trying to merge with Radio Shack in the 1970s and still exists as well.
  19. #99 Posted Aug 23, 2017
    Aug 13, 2008
    10,209
    3,788
    The Land of Oz
    Oh please...please...dood...don't get me started. I do miss being able to go to RadioShack and get whatever components I need - now I gotta wait on the mail. Growing up, they always had the coolest cars and other RC toys. My brother had a hovercraft, and he played with it until the seals rotted and it sunk. The sucker lasted for years, and he ran it in the pool, YMCA, and even a lake. I had a '58 Impala, a beautiful toy that I still own. In fact, several years later, I bought two NOS bodies and two NOS wheel sets for the front for it. You can't buy toys anymore and expect to buy replacement parts at any point in time these days.Granted, that was years ago and I have heard that the customer service area was cut and less-experienced people were hired and paid less. The same decision helped kill Circuit City 10 years ago.
    Whatever you bought that was electronic, you could bet that RadioShack would carry parts to fix it - especially if they sold it. Their mistake was trying to abandon the niche that made them great and got into cell phones. THEY SHOULD HAVE GOT INTO PC GAMING! Have you seen the guys and gals that are into that hobby? They build their computers from the ground up, or buy one and upgrade it, spending hundreds and thousands of dollars on them, the games, the accessories, etc. RadioShack's leadership missed that gravy train, and the marketing team who ignored that ought to be ashamed and embarrassed to call themselves salesmen and marketers.
    Tar and feather 'em...I says...
    #99 partsguy, Aug 23, 2017
  20. #100 Posted Aug 23, 2017
    Feb 6, 2012
    2,632
    1,136
    Earth
    I think GameStop is the Radio Shack of gaming...we have or had one, dunno, not my forte. I fix up computers for internet use and playing media.
