1968? Schwinn Paramount i.d. help
juvela
1,263
Playa del Rey, United States
wrt Cinelli stem/bar set from dealer -
the stem will have a clamp size of 26.4mm
if the bar you select to use with it is not a Cinelli you will likely need to shim it
most common bar centre sizes are 25.0mm, 25.4mm and 26.0mm
please do not rely upon pinching down the clamp for a fit
there appears to be a marking on the underside of the cantle plate of the Brooks. be it confirmatory of the 1968 datum?
Reactions: buses n bikes
