Nice, clean bike! Looks to be nearly all original too. The safety levers appear to have been removed and the gum hoods were added. First generation Dura Ace crank and excellent-performing Shimano derailleurs. I believe the bar-end shifters were made by Suntour.
The YFC saddle and toe clips/straps are almost always missing on these. I had one for a few years - very nice riding bike.
in case you should wish to change the stem in order to better fit the bicycle to yourself be aware that the steerer is likely to be the .833 size so you will need a stem which is compatible
the machine's KKT RTSF-AL pedal set is probably its worst component. the counterbalance pedal design makes them vulnerable to catching on the ground during cornering. suggest upgrading to a better pedal if you are going to be using the bicycle. of course you may prefer to keep it as all-original as possible.
