Saving Tempest
In fine working order, was rebuilt about five years ago in a complete restoration. Asking about half of what that cost, $175. Will provide a new generic headshell if needed, you can install your own cartridge as you like. Also have a Pioneer PC-11 cartridge with no needle, one can be had cheap online but it's conical and from an older model, you can have it if you want though.
Stuff from the manual:
The Pioneer PL-610 is a two-speed, direct-drive turntable with integral tonearm. Features include:
Quartz PLL brushless DC hall motor
Precision engineered parts for excellent speed performance
Electronic auto return mechanism
Handy quick play function
All electronic durable quick stop function
No-howl vibration resistant coaxial suspension system
Specifications
Drive system: direct drive
Motor: Quartz PLL Hall motor
Platter: 330mm aluminium alloy diecast
Speeds: 33.33 and 45rpm
Speed control range: +-6%
Wow and flutter: less than 0.025% WRMS
Signal to noise ratio: more than 75dB
Tonearm: static-balance type, S-shaped pipe arm
Effective length: 237mm
Overhang: 15mm
Cartridge weight: 4 to 12.5g
Arm height range: +-3mm
Dimensions: 470 x 148 x 418mm
Weight: 12kg (that's almost 27 lbs. for the turntable alone)
Sub-functions: auto return, quick play, quick stop, anti skating force control, stylus pressure direct readout, arm height adjustment, cueing device, pitch meter, free stop hinges
A few scratches on the lid, Wood side panels, moderate and expected wear for an approximately 37 year old turntable but in overall clean and nice shape.
Ships from 97914, Ontario Oregon, your choice of carrier.
A shot from my home and three from the yard of the guy that rebuilt it (he likes to take glamour shots of his work from his yard next to a hill in California).
Specifications
Overhang: 15mm
