petritl
Rust free TX bike hauler for sale, very reliable..
A lot of work has been done to the truck since it was rescued from a farm pasture in August:
Brakes:
Front pads
Brake hoses
Calipers
Rear wheel cylinders
Brake fluid flush
Cooling system:
Radiator hoses
Bypass hose
Heater hoses
Flush
Cooling fan clutch
Thermostat
Fuel system:
Rear tank
Rear fuel pump
Front fuel pump
Fuel selector valve
High pressure fuel pump
Fuel pump relay
Fuel pressure regulator
Fuel filter
Electronics:
ECM
ECM relay
Idle air control valve
Throttle position sensor
Battery
Battery cables
Ignition module
Ignition:
Spark plugs
Spark plug wires
Suspension:
Radius arm bushings
Tires
Misc:
Air filter
Blower motor
Transmission filter
Transmission fluid; drain and refill (inc. torque converter)
Power steering fluid change
Repack front wheel bearings
Replace hub seals
Drained and refilled differential lube
I over repaired the truck because I intended on my soon to be 16 yr old to drive it.
Reason for selling:
The family has decided they would like to go camping so I now need a truck capable of hauling an RV , wife, two kids, and two dogs.
Brakes:
Front pads
Brake hoses
Calipers
Brake fluid flush
Cooling system:
Radiator hoses
Bypass hose
Heater hoses
Flush
Cooling fan clutch
Thermostat
Fuel system:
Rear tank
Rear fuel pump
Front fuel pump
Fuel selector valve
Fuel pump relay
Fuel filter
Electronics:
ECM
ECM relay
Battery
Battery cables
Ignition module
Ignition:
Spark plugs
Spark plug wires
Suspension:
Radius arm bushings
Tires
Misc:
Air filter
Blower motor
Transmission filter
Replace hub seals
Reason for selling:
