36 Firestone Fleetwood
@Balloonoob Would you be able & or opposed to putting a shim under the bearing race? It could give you some clearance Clarence if you have enough threads on the neck jus' to get it riding ....until you get a fork or the 1 You want.
That might just work. I've used this trickery to gain clearance for a chain ring before but never thought to use it on a fork. The reality is that this fork looks like crap and has to go soon anyways.
Hi Nate. Yeah in post 7 I just staged up the guard. I received a patina matching wald3 stem from @SKPC (thanks Pete!) which looks great! I'm looking forward to a swap on April 10th..... Who knows what I'll find there. For now it's a roller but not yet done.
I found the correct fork a while back on eBay and reluctantly stripped the repaint off of it and rusted it up all day today. I then (likely prematurely) gave it a grease bath which will need hosed off and probably wiped down tomorrow. I was going to put a set of maxxis hookworms on it but I'm not sure that 2.5 inches of tire will fit in the fork. I have another set I might weasel off of another bike. Still need a rusty drop center wheel for the front. The modern wheel I had on the front was awful and is not going back on.
Nope. 2.3 barely fits, with an occasional rub in a quick turn.
I dig what you're doing with it; take your time, no rush.:cool:
1411826
Rotated tires with the recent spoke re-new.:blush:
Edit add: look close at the bee-hive and bees on the bottom of that sign!
Appeared over-night, haven't seen it since.:hearteyes:
